Just changed oil after initial break-in-->
Old May 10, 2001 | 08:17 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Got a question for you guys, I just changed the oil on the new motor after the cam break-in. After removing the filter I watched it drain and saw alot of tiny bronze specs in the oil. Obviously these are from the bearings, should I be concerned or is it fairly normal. The reason I ask is because this motor already ate up a thrust bearing (after a mere 4K miles) last year before being rebuilt.
Thanks,
James
Old May 10, 2001 | 08:21 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
sorry, but i don't think that is normal. i didn't see any of that crap in my oil after break in. why did it eat the thrust bearing? if you didn't fix the problem, it may be doing it again.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
406 balanced with 6" Eagle H-beam rods, 10.25:1 JE SRP pistons, Comp 284XE cam; 240/246 @.050, .507/.510, Dart 200cc Ironeagle heads, Victor Jr. intake, Holley 750 vac sec.
12.20 @ 115.25 mph
Old May 10, 2001 | 09:00 PM
ede's Avatar
ede
my question is what was the thrust clearance? it should be between .002 and .006, did you check it? did you check the crank for run out? did you check the bearing surface in the block and caps fpr out of flat? have the block alighned honed? if all of that is good i don't have any idea what your problem maybe.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 10, 2001 | 09:10 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Bronze or copper?
Do you have a bronze distributor gear?
Old May 10, 2001 | 09:25 PM
406TPI's Avatar
Car: 1985 IROC-Z
The block was align honed and a new cast crank was put in. The endplay of the crank was .005
Nobody that I talked to after it ate the thrust bearing the first time could give me a diffinative answer as to why it happened. The shop that did the machine work the second time didn't even know.
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
