How do you test for open and closed loop??
Old Jul 25, 2000 | 01:37 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I don't have a diacom or any other scan tool for that matter. Is there a way that I can test for open and closed loop?
Thanks,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
Old Jul 25, 2000 | 03:49 PM
Cntrvrsy's Avatar
I believe it's jumping the ALDL connector while the engine is running. The SES light will flash steadily. I think quick flashes means open loop and slow flashes mean closed loop. I'm positive though, I can't find that section in my book. But it's something like that.
Old May 10, 2001 | 09:29 PM
86Trans Am's Avatar
Does anyone know if this method of testing open/closed loop is correct?
thanks
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old May 10, 2001 | 09:50 PM
Guest
Guest
Posts: n/a
Its correct. Dont do that on carbed cars tho.
Its 2 1/2 times/sec open loop and once/sec closed loop. You can even tell if its rich or lean from the light, I forget which is which, but it either stays on a long time or off a long time, and one way is lean and the other is rich. Not real accurate, but neither is an o2 sensor.
GTAman
Mar 15, 2019 11:40 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
