hotter cam
Old May 9, 2001 | 11:05 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
hotter cam
I'm thinkin of getting a new cam for my 1984 stock trans am (L69), what should the exhaust and intake duration be? Will I need new retainers and springs. I don't want to get too radical of a cam, but i would like some more power. Any suggestions? Also I need to pass emmissons
[This message has been edited by 84 t/a 5.0 (edited May 09, 2001).]
Old May 10, 2001 | 07:13 PM
Cosmik Debris's Avatar
A good cam for an L69 is a comp cams 256 xtreme energy grind (212/218 @50). This will give a power peak at about 5500. The 262 (218/224 @50) is also good but will push the peak to 6000 and may require some head porting to really get the full benefit.
Old May 10, 2001 | 08:13 PM
84 t/a 5.0's Avatar
will the 256 extreme energy cam be too much for emmissions and the computer or will i have to get a chip
Old May 10, 2001 | 09:03 PM
84 t/a 5.0's Avatar
what else would i need to get with the XE256? Retainer, springs, will it work with the computer?
Old May 10, 2001 | 11:34 PM
Those cams have a 110 LSA and may not be computer friendly. I don't think of L69s as having a computer since most of the ones I have seen have been modified. Someone else may have some input here. Crane make a seies of compucams which are OK.
Old May 11, 2001 | 12:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Any time you change a stock cam, you should get new springs. Also on a non-roller cam, you must get new lifters as well.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Bubbajones_ya
Jul 6, 2024 08:32 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
tommy z-28
Oct 6, 2015 10:58 PM
masonta
Sep 1, 2015 06:40 PM
