cooling problem
Old May 11, 2001 | 12:48 PM
uno's Avatar
uno
cooling problem
Ok check this out..Today I was foolin with my car and i was letting it idle and reving it up...Well my temp went up slowly to over 260...but my radiator and radiator cap were cool as the other side of the pillow....What's up with this??? I just replaced the thermostat a week ago...I am pretty sure it's flowing coolant because it's kinda leakin from around the thermostat housing...i have replaced the radiator hoses also...what's goin on here????
1989 307 RS, soon to be 350.
1995 Red T-Top Camaro, 3.73 gear, F.I.P.K. K&N,Flomaster Cat-Back, Gutted Cat...Killer Stereo (Cerwin Vega and Sony Xplode)
Old May 11, 2001 | 12:52 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
Could be a stuck thermostat or installed upside-down. Maybe it's kinda leaking at that point because it has nowhere to go.
Old May 11, 2001 | 01:01 PM
uno's Avatar
uno
i put it in the same way i took the other one out...the pointy side up right?
and also there were lil trails of smoke comin out of my carb like maybe 3 or 4 times
Old May 11, 2001 | 01:05 PM
89ragtop's Avatar
Maybe you have a blockage somewhere else. Heater core or hoses leading there, also check the coolant reservoir hose. Sometimes all the gunk in there collects on the bottom and can plug up that hose, so your coolant level is incorrect.
BTW, I bought a NAPAthermostat for my truck at it was junk right out of the box. Put it in a pot of water and let it boil, then grab it out with a pliers or something and make sure it opens. Real easy way to test it.
[This message has been edited by 89ragtop (edited May 11, 2001).]
Old May 11, 2001 | 06:16 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Although most water pumps seem to leak out of that weep hole when they go bad, not all do. I had a similar problem on a Nova once, replaced the thermostat, the hoses, the radiator. Still ran hot. My dad said water pump! I didn't believe him till I had nothing else to change. It was the water pump. No, or not enough flow, even though it never leaked a drop. I'm not saying change it, but keep it in mind if all else fails.
Z's r Best
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
