Stuttering
Old Sep 16, 2004 | 05:38 AM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
Stuttering
My car stutters from 1000 to 1500 RPM, and it's pretty annoying since that's where my car is for 20-25 mph driving (through my neighborhood). Car runs fine after 1500rpm and before 1000rpm. Stuttering happens while daily driving under light throttle, and under a little more aggressive driving. Any suggestions?
Old Sep 16, 2004 | 08:34 AM
bobsroc's Avatar
Car: 1987 IROCZ
TPS sensor, vacuum leak would be where I would start.
Old Sep 16, 2004 | 06:21 PM
the TPS and IAC are both brand new. I haven't checked for vacuum leaks yet. Any tricks of the trade for this? I've heard to take a cigarette and let the smoke drift over the engine and look to see if it gets sucked in anywhere.
Old Sep 16, 2004 | 06:31 PM
sellmanb's Avatar
Car: '86 Berlinetta
that's also a good way to find out if you've got gas leaking badly around the carb or runners
Old Sep 16, 2004 | 06:45 PM
bobsroc's Avatar
Car: 1987 IROCZ
My trick is a vacuum gauge.
Old Sep 16, 2004 | 08:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Hardly a trick
But they do work....
Old Sep 16, 2004 | 08:53 PM
I've never used a vacuum gage. Where would you hook it upto? just any vacuum port? I'll pick one up from Autozone over the weekend. What indication should I expect?
Old Sep 23, 2004 | 06:55 PM
It seems that I forgot to plug in the vacuum sensor for the ECU one of the times that I had to remove my valve covers. I noticed this today, plugged it in, and now my troubles with stuttering seem to have disappeared.
Old Sep 23, 2004 | 08:34 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Isn't it amazing how many times we are our own worst enemy. I've been there, done that too. More than I care to admit here anyway
Glad you got it fixed.
racereese
Oct 3, 2015 03:46 PM
89BlueTA
Mar 14, 2002 06:00 AM
Night Hawk
Feb 19, 2002 07:20 AM
Night Hawk
Feb 17, 2002 06:57 PM
