How to pass smog tips
Old Sep 23, 2004 | 12:28 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
anyone have simple little tricks to do that will help just a little bit on the tail pipe test? like i was wondering if i was to remove the air cleaners completely and just run straight air, it would allow more flow, would that improve the tail pipe test results? anyone else have any ideas?
Old Sep 23, 2004 | 01:56 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A little alky in the gas tank helps from what I hear. So does getting the engine pretty hot right before the test (dont test cold).
Old Sep 23, 2004 | 02:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Drygas.
Have you failed and are wondering how to pass? Or are you just trying to cheat your way through, knowing your going to fail? If the former, what were the results? If the later, what's the combo?
Old Sep 23, 2004 | 02:10 AM
QuickStyle's Avatar
Car: 91 Z28
im just curious cuz my car is just border line before failing. ive heard of the alcohol in the tank trick, is it just rubbing alcohol? and how much should be used? and would removing the air cleaners to allow more flow be helpful?
Old Sep 23, 2004 | 02:23 AM
Air_Adam's Avatar
Dont bother removing the filters. Clean filters will be what you want. The computer compensates for the extra airflow anyway, so it won't work like you might think. It might on a non-cc carb setup, but not TPI. Good thinking though.
Old Sep 23, 2004 | 04:16 AM
QuickStyle's Avatar
Car: 91 Z28
what about the alcohol in the gas tank??? is it just rubbing alcohol?? how much of it are you supposed to use?
Old Sep 23, 2004 | 08:15 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No it is not quite that simple. Just go to any auto parts store and look for the stuff that is called "always pass" or somthing along the lines of that. Also, use the stock air cleaner assembly and back your timing off a bit. Even running a few degrees advanced can drastically change the emissions in any engine. Overall just make sure your car is ain a good state of tune.
Old Sep 23, 2004 | 02:47 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I see your in california...
You know that you have to pass a visual as well, so you need your filters in place. You also need stock timing and idle. Make sure your EGR and Cat Converter are still functioning.
Old Sep 23, 2004 | 08:35 PM
QuickStyle's Avatar
Car: 91 Z28
they dont check for air filters in place, i know that "gaurantee to pass" liquid works pretty good, but i was just wondering about little things that help, thank for all the input
Old Sep 23, 2004 | 08:41 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
umm how about move to a state that doesn;t require it ?
i have no clue other than what works for me.
keep your car tuned proper
change oil often
fix stuff before it falls apart
if it sounds broken it probally is
and run the car for at least 20 min driving not idle.
jeff
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
