Roller cam swap question
Old Sep 16, 2004 | 08:50 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Of course when you replace a cam you replace the lifters because of wear, but what about roller cams and roller lifters? The only wear that I could imagine is on the edge of each wheel on the lifter. The reason I ask is, if you swap out your roller cam with another, this is a 300.00 chunk of change, the roller lifters seem to be another 300.00 chunk. Thats 600 bucks for a cam swap! Thats just not worth doing to a 305... Anyone know if you have to replace those lifters and technically why?
Old Sep 16, 2004 | 08:56 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Good news! you can keep your old lifters and re-use them. Guys do it all the time.
Old Sep 16, 2004 | 08:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup, like streetiron said, they can be reused. Roller lifters obviously have that roller bearing which takes away the big wear tear factor. That same factor is what prevents you from using new lifters with an old cam or old lifters with a new cam, in the case of a flat tappet cam.
Old Sep 16, 2004 | 09:12 PM
Thats cool, I though as much but the more I think about it the more that I'm like "what if what if" THANX!
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
