305 center bolt valve cover washers
Old Sep 16, 2004 | 10:05 PM
yellow73bb's Avatar
While removing the valve covers to replace the valve seals on his "new" 1989 firebird, my son lost two of the copper washers that go on top of the covers under the heads of the bolts. Are these anything special? I can't seem to find them on the autozone site, what are they called?
'nother question. When we had the valve covers off, the rocker arm area was really grungy. What is the best thing to put in there to clean it up? We're planning to change the oil and filter a couple of times, so would like to run something to clean it and then put in clean oil
Any help greatly appreciated.
Thanks,
John.
Old Sep 17, 2004 | 06:25 AM
ede's Avatar
ede
try gm parts or a junk yard. if all else fails try mc master-carr for some copper sheet, might even be able to find washers from them.
Old Sep 17, 2004 | 12:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would say junk yard for the valve cover washers. Any SBC centerbolt valve cover should work. Second guess would be some cheapo washers.
As far as the grungy-ness, there are several solvents out there that can be used. GM top end cleaner comes to mind. I've put some transmission fluid in mine before.
However, depending on how many miles are on the car, and what type of grungy build up it exactly is, sometimes the best thing to do is just leave it where it is. Break that stuff loose, it finds it's way to the pan. The pump sucks it up and it clogs the pickup, then you've got even mroe trouble on your hands than what you started with.
Old Sep 17, 2004 | 12:29 PM
yellow73bb's Avatar
Thanks for the input. I called the chevy dealer and they said there is nothing special about the washers to keep them from leaking oil. They just leak oil.
Maybe we'll get some small rubber washers to put under the metal washers or something.
Old Sep 17, 2004 | 08:51 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
I went to Ace hardware and got the 1/4" rubber washers and no leaks so far
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
