how to improve airflow to rad?
Old May 12, 2001 | 08:09 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hello to all.
is there anyway i can improve the airflow through the radiator? maybe some kind'a scoop like on the airplanes ? does sombody knows if there is something around for the purpose?
thanks to all for your time.
fernando.
third gen muscle power is the only thing that can match the power of flight...
Old May 12, 2001 | 09:02 AM
Vader's Avatar
There should already be a set of lower air deflectors on the front of the radiator support, comrade. There are two baffles to deflect air away from the sides of the radiator, two fillers on the bottom edge of the fascia to seal the front of th fascia to the wheel openings, and the center air deflector (air dam) that is often missing due to close encounters with parking curbs (or F-15s). Make sure you have all the necessary parts, and replace those that are missing.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 12, 2001 | 10:10 AM
The ODB's Avatar
Yes,
Mig29 you don't say what you drive, but the general answers are this.
Get an airdam (mounted to lower radiator support) that drops down at least 6 inches. Block off all other sides of radiator (sides & between the top support and hood) so that air cannot easily bypass the radiator core.
Next you can tilt the top of the radiator back towards the engine, but keep it sealed against the hood with some kind of gasket.
Old May 12, 2001 | 10:07 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
ok, it is a camaro 87, ex 2.8 (crap)ex 305 and finally a much better 350 4 barrel carb, 5 speed manual.
i'd like to thank you both for your help tabaris (camarad in russian). it turned out to be as vader said "missing deflectors" probably lost at the parking lot or few 30mm. rounds from an F-15 (mean machine)
i'll get the parts and thanks again
camaros are forever !!!
fernando.
Old May 12, 2001 | 11:07 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm working on picking up all the deflectors from a local salvage yard, and have installed only the one that goes around the hood latch and the air damn. My car seems to be running lots hotter than last summer! I'm going to try taking the panel around the latch off, or install the 2 side deflectors soon to see what helps.
I'm really disappointed, because it ran really cool last summer. Maybe I'll get a new stat while I'm at it. Could also be a good time to switch to dex-cool, although that will most likely happen when the "Monster Motor" goes in.
The point I'm trying to make is this though :
Maybe having just some of the deflectors is worse than none?!?!?! Anyone experience this sort of thing, please reply!!!!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
[This message has been edited by JP84Z430HP (edited May 12, 2001).]
Old May 13, 2001 | 12:01 AM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Try lifting the plastic piece that is on top of the radiator & covers the space between it & the air conditioner condenser. I have noticed that debris tends to build up in that location (leaves, trash, etc).
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
F-body-fan
Jan 12, 2023 01:49 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
wanext
Oct 6, 2015 12:18 AM
Stryker412
Sep 20, 2015 06:59 PM
