can crank hit oilpan?
Old May 12, 2001 | 09:29 PM
virtual's Avatar
i got motor put in my 83 z28 its 305 anyway when they put it in it was knocking buddy said engine was gone but another guy i know said could be crank hitting oilpan becouse thats were the noise is coming from.can this happen?if so how will i know if it is hitting it Please help?
Old May 12, 2001 | 10:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Only way I counld see the crank hitting the pan, is if there was a huge dent in it.
Ofcouse all the main bolts could have fallen out too
Lower end knock is probably bearings.
Old May 12, 2001 | 11:34 PM
CamaroX84's Avatar
If your crank is hitting the oil pan, you have a serious problem. When the crank even dips into the oil, it will spin it so fast and put bubbles into the oil . This is like having virtually no oil, because the oil can't lubricate anything with all the bubbles in it. Look at the oil. If it is like a white foam, that is what happened. Either a dent in the oil pan which made the oil level in the pan rise to high and hit the crank, or there is too much oil in the motor. Like Mike said, it is probably a rod bearing. Good luck. Hope this helps.
Old May 13, 2001 | 12:08 AM
Bort62's Avatar
Ive had this happen Before, one of the counterweights on the crank was contacting the bottom of the oilpan, this was on a regular 4bolt Main 350.
a thicker, one peice felpro gasket solved it, but it was very strange. It actually wore a little hole in the semi-windage tray thats in the bottom of the stock pans.
Why Did it do this ? I have no freakin idea.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
80smetalfan
Sep 22, 2015 02:55 PM
87camaro87
Sep 9, 2015 10:29 PM
