Headlight motor assembly question
Old Sep 20, 2004 | 02:25 PM
KeenEddie's Avatar
Car: 1989 Pontiac Formula 350
My drivers side headlight isnt going up, but its turning on. I ruled out the switch, because the passenger side light still works. I figured it was the relay, but I have an assembly question about the motor.
A few weeks ago I rebulit the headlight motor. Then the gear starting jamming, so I ripped it back apart. At the top of the motor shaft there are two springs held in by two little metal pieces, each attached to a wire. One of them had come off and got stuck in the gear. I removed it, replaced the springs and jammed the wire that had the piece broken off into the spring against the motor, and it worked fine.
Now my headlight wont come up. When this first started it wouldnt go up, but if you started to move it along manually it would go the rest of the way. Now that doesnt even work. Could that little piece off the wire be giving me this much trouble? Or is a bad relay to blame? I havent had the time to switch the relays yet to test it.
Old Sep 20, 2004 | 03:37 PM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
This is a forum that I am a member of and here is a link of a few of my 3rd gen tech articles on headlight fixes if you don't figure it out......leave some feedback if you have questions....
http://firebirdnation.com/index.php?showforum=35
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
