file fitting rings - do YOU compress the ring to do both sides of the gap?
Old May 13, 2001 | 10:55 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I had always thought that you should try to keep it square by compressing the ring so both sides of the gap would be touching on the grinding wheel. But I recently saw someone only doing one side. I admit, my fingers would have liked it better but I don't see how you can keep the filed end square like that. I had a devil of a time even keeping it square anyway. I guess you would only have to file one side and since the other side was untouched, it would remain square.
Old May 13, 2001 | 11:11 AM
Vader's Avatar
JCB,
If you could be certain that the side you ground/filed was a perfect radial after you finished, you could get away with filing only one side. That, of course, is presuming that the original ends were perfect radials to begin with.
I would prefer to dress both sides, assuring a good fit regardless of the final angle left at the ends. But I think you already knew the answer to that one...
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 13, 2001 | 06:18 PM
ede's Avatar
ede
i only file one side, my ring filer does a pretty good job of keeping the end the same as long as i take my time and set it up before i start. if you've never filed a ring before it doesn't take much to increase the gap.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 5, 2015 11:57 PM
