A Tale of Two Balancers
Old May 12, 2001 | 04:50 PM
Bort62's Avatar
Allright, In the world of Internally Balanced SBC's, we have Two Balancers. The One with the Strait Up Timing mark, and the Other one.
The Lg4 has the "other" one, and I just bought a strait Up, to replace it.
My Question For you, Is How many deg off Is one mark from the other, IE where should I make my "correct" Mark. I would Simply trace the line over from the old balancer, But with 150k On it, Its accuracy is suspect, and hence the reason for this whole undertaking.
Thanks...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 12, 2001 | 05:33 PM
snoozeyaloose85's Avatar
I had a problem like yours I put a balancer from a 79 305 on my 85 305 tpi ta. And couldn't figure out why the timing marks were so off. So ended up pulling it off and matching the timing mark with the other And I think I got it pretty close. Another way is to find top dead center of compression stroke for #1 cylnder and the balancer should be at 0tdc.
Old May 12, 2001 | 07:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
2 1/16 inches should be REAL close.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old May 13, 2001 | 07:28 PM
84FTA's Avatar
Just for anyone that may later archive and find this post:
For your 6 and 3/4 balancer, the degrees are as follows
(6.72/2)^2 * pi = 35.7665" circumference
35.7665"/360 = 2.125/x
x = 20.389 (crank degrees, so since 2.125 isn't exact, go with 21 or 20, 20 is nicer)
So it should be off by about 10 cam degrees.
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old May 13, 2001 | 09:52 PM
Bort62's Avatar
haha, Yeah I should have thought of that 84
Oh well, Thanks guys.
monte87cortez
Sep 26, 2015 08:10 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
roysatikas
Sep 22, 2015 08:15 PM
Magman
Sep 13, 2015 12:14 AM
TheExaminer
Sep 6, 2015 11:40 PM
