Smog pump help
Old Sep 22, 2004 | 07:03 AM
wc00ac's Avatar
Car: 92 Camaro
Engine: 305 TBI
Smog pump help
When I get rid of the smog pump and all the hoses, what size belt will fit my car? And is there a part number? Thanks
Old Sep 22, 2004 | 08:50 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
You may want to try doing a search, as I know it's been covered many times.
If you have a serpentine belt setup (I'm assuming you do, since your car is a '92), I think you'd need a smog pump delete pulley. Don't hold me to this, though. In that case, the belt size would remain the same. However, it may also be possible to just buy a shorter belt, provided that it doesn't interfere with any bracketry.
I'm used to working on V-belt cars. I don't have a smog pump... all I had to do was pull the pump and remove the belt.
Old Sep 23, 2004 | 01:20 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
You can run it with out the smog pump. you just need to get one that is a little smaller and try it out. I might take a few trips to the parts store though.
Kevin
Old Sep 23, 2004 | 02:08 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I just went up to autozone and told them I had a 95 chevy 1500 with a 350 tbi and had them give me the belt for one without a smog pump and with a/c and it fit like a glove. Good Luck.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
