question about removing ac
Old Sep 22, 2004 | 06:39 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
hey my buddy has a 91 rs and wants to get rid of the ac. the question he has is will a pully system from an 89 truck without ac work or will the hood hit the brackets? another question is if that works, what about the thing that holds the compresser thats on the firewall, can you remove that? thanks guys
Old Sep 22, 2004 | 07:35 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Why not just get a $30 A/C delete pulley from GM parts direct instead of switching brackets? Will work a ton. Search for A/C delete and you will find tons of info.
AS for the box,yes you can remove it. You will need either a heater only box like in the 1le cars, or block off the hole if heat isn't needed.
Old Sep 22, 2004 | 07:57 PM
Car: 89 trans am
Engine: 355
well we we thinking this but the belt tensioner is on the ac compresser so will the ac delete still work?
edit: also will parts stores have the heater motor he will need? what options does that 1LE car come with so that the people looking up the part will know if it is the heater only box?
Old Sep 22, 2004 | 08:12 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yes, the AC delete pulley will still work. If you look closely, the belt tensioner is next to the compressor, it's not actually on it.
You can't get non-AC heater box from an auto parts store. Your options are to either get a new one from the dealer, get one from the junkyard, or just keep the stock one but plugs the holes or make a block-off plate.
I completely removed the AC from my 91 RS. It's not hard. Just remove the compressor and install the delete pulley, remove all the lines, remove the condensor (the large piece in front of the radiator), the reciever-drier (the cylinder-shaped piece attached to the heater box). Now you can either plug the two holes that go into and out of the heater box, get a non-AC heater box, or remove the top plastic piece, remove the evaporator (the gold-colored piece inside the heater box) and make a block-off plate (I just got done making my custom block-off plate 2 days ago, it's not hard, all you need is some metal, some way to cut the metal, and RTV).
I can go into more detail if necessary.
Old Sep 22, 2004 | 10:16 PM
Car: 89 trans am
Engine: 355
alright i got it. thanks a bunch
Old Sep 23, 2004 | 09:18 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Bout like this....
Old Sep 23, 2004 | 09:19 AM
BIGJON's Avatar
Non AC heater box from Ebay....
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
