oil pump question
Old Sep 22, 2004 | 06:56 PM
kidcamarosc's Avatar
oil pump question
I bought a summit oil pump which I think is a M55 pump anyways but my question is the intermeidate shaft that came with it has a steel sleeve. Does it just sit onto the pump shaft cause it really doesn't stay on there real good. Im trying to assemble my engine and wondering how I can keep it from falling out when the engine is flipped over.
Old Sep 22, 2004 | 07:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It won't fall out, don't worry. The sleeve will get caught on the hole in the main cap that it goes through. It can't even move far enough to allow the drive to disengage. It's designed that way.
Old Sep 22, 2004 | 07:37 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
RB beat me to it, but that is correct. It won't go anywhere.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
