can you hone a cylinder with a stone hone?
Old Sep 22, 2004 | 08:08 PM
NoUseAbleNames's Avatar
i was told you are only supposed to use a ball hone is this true? whats the reason behind this??
Old Sep 22, 2004 | 08:54 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i just finished honing my 350 block tonight. it gets rid of the scores and unwanted carbon. shines the cylinders up pretty good. time consuming, pays off though.
i did use a stone ball hone and a drill to do this job. worked very good
Old Sep 22, 2004 | 09:14 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
A 3 stone hone can end up causing the cylinder to be tapered. The object of honing is to break the glaze on the cylinder wall, with a 3 stone its almost like youre trying to bore the cylinder. But without any alignment. Also the stone hone will remove more material from the center of the cylinder instead of the ends.
A ball hone does a real nice job very quickly. It removes very little material but produces a nice finish easily.
Old Sep 22, 2004 | 10:16 PM
gotcha, i see why too.
thanks
Old Sep 22, 2004 | 10:42 PM
is tranny fluid a good lubricant to use during a hone job?
Old Sep 23, 2004 | 04:41 AM
ede's Avatar
ede
if all you're wanting to do is remove the glaze a stone type hone will work fine. it doesn't remove enough metal to change the size or shape of the bore. ball hones are great but a stone hone works. if you're wanting to increase bore size you need to take it to a shop and have it done on a boring bar.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
