Can't start my 92RS
Old May 13, 2001 | 12:09 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Can't start my 92RS
Its been sitting on the street for a few months without being started. The car will make a loud sound like the starter hitting against the flywheel, but only once, and it doesn't have enough power to turn the engine. Occasionaly, it turns the engine like half a turn, but that's about as far as it will go. I know its not the battery cause i tried it w/ a good battery and i even tried jumping it. It still does the same thing. When i checked my oil, there was a thick slump of oil on the dipstick w/ what looked like metal shavings. Is my engine seized or what? Thanks
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old May 13, 2001 | 02:49 PM
Blue92's Avatar
Did you do any work on it before this started? Anything at all? This will help narrow it down some if you have.
Old May 13, 2001 | 03:53 PM
Car: 88 IROC
Transmission: auto
I only replaced the distributor cap, injector pad, and egr valve. These three werer off the car for several months as well. I didn't touch the motor or anything else that would cause this problem. I'm thinking that it might have been possible for some water to get into the engine and mixed with oil which then rusted interior engine components. There was some water on the dipstick also. Or maybe the starter is not getting enough juice from the battery?
Old May 14, 2001 | 11:30 AM
Blue92's Avatar
I know this sounds stupid, but make sure everything is connected to the distributor and that your wires are hooked up in the right order. Even underneath your cap. Later, Blue
Pics of my Car
http://albums.photopoint.com/j/View?...781&p=39417549
http://albums.photopoint.com/j/View?...781&p=39417539
http://albums.photopoint.com/j/View?...781&p=29492902
http://albums.photopoint.com/j/View?...781&p=29492901
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
tero
Aug 15, 2015 02:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
