Air Pump
Old May 13, 2001 | 03:29 PM
Z28DJP1987's Avatar
Air Pump
Will a air pump thats going bad cause a surge
at idle and stumble or miss at road speeds??
Anyone have any thoughts on this problem?
This is about the only original emmission part on the engine.
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam: 450lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors
SLP Intake runners
New Computer chip
K&N filters & Air Foil ,
Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
Limited Slip rear
245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
EST. 340HP
380#/ft of Torque
NEW TOY!
Old May 14, 2001 | 01:35 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I seriously doubt it. The only thing the AIR pump is there to do is pump oxygen into the manifolds and converter to help use up unburnt fuel for cleaner emissions.
my $.02
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old May 14, 2001 | 01:47 AM
Jester's Avatar
No, and air pump won;t have anythign to do with that. On a TPI engine tho, those symptoms could be caused by about a hundred things, I'll leave that part of the question for someone more familiar with it.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 14, 2001 | 01:53 AM
rezinn's Avatar
You could take that thing out and the only difference you will notice is a bad smell from the CAT not working at its full potential :P
There are probably 150 problems you could have, just search the board for "surge" or "bad idle" or whatever. I have some thoughts on this problem: it sucks! I would hate if my car did that!
Old May 14, 2001 | 09:43 AM
Z28DJP1987's Avatar
Thanks for your input. I will look in another direction for a solution.
Old May 14, 2001 | 11:32 AM
Steve89GTA's Avatar
I've been trying to fix my surge problem for months now. New fuel pump, filter, plugs, entire distributor assembly, wires, coil, battery, alternator, CTS, TPS, IAC Cleaning **** it...these cars are POS's by today's standards that's for sure so I just enjoy it for what it is...nothing more.
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
