2.8L Fiero Timing (anyone know)
Old May 14, 2001 | 09:37 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Where is the wire to disconnect so you can set the Timing. I just put a new motor in my wifes car and don't know where this blasted wire is so I can set the timing. I have adjusted it the best I can with a timing light but I am still way too far off because the exhaust starts to glow after about 5 mins. The cat is gutted so I know its not clogged. It has all new injectors so I can't imagine that would be the problem. So please help me set the timing properly.
Old May 14, 2001 | 12:45 PM
Vader's Avatar
BR,
I'm not certain on the 2.8, but the 151 doesn't have a bypass connector - the ALDL diagnostic pins are shorted to force a base timing mode. Your might be similar.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 14, 2001 | 01:10 PM
ede's Avatar
ede
little more info on year might help. i found the info in a manual the only time i worked on a fiero. like vader said i had to jump the ALDL.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 14, 2001 | 01:36 PM
86 2.8L MPI (which all the V6 Fieros had). Jump the AB pins on the ALDL connector or other pins.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC
*Turbo City Inj Spacer
*Dual Snorker Air Filter
Please Visit www.bnhtoys.com and www.bharris.org
fcorallo
Aug 20, 2015 11:28 PM
BurlyChev
Aug 16, 2015 09:08 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
gwade12
Aug 8, 2015 08:17 AM
