OIL AND POOR IDLE
Old May 14, 2001 | 12:21 PM
88ROBERTGTA's Avatar
OIL AND POOR IDLE
HEY GUYS,
I HAVE A SMALL AMOUNT OF OIL COLLECTING IN THE MANIFOLD WELLS ON THE PASSENGER SIDE RIGHT NEAR THE FRONT TWO INJECTORS, DOES NOT LOOK LIKE ITS COMING FROM THE VALVE COVER, ANY HELP, ALSO IF THE RUNNERS WERE LEAKING WOULD IT CAUSE A ROUGH IDLE, ANY WAY TO TELL.
THANKS
ROBERT HILL
Old May 14, 2001 | 04:51 PM
poncho9789's Avatar
The oil is from the crank case vent or the pvc valve it is normal to have a little oil to get into the intake. If your runners are leaking the computer will not regester all the air that is coming into your engine therefore will run differently than if it was regestering all the air that was coming into the intake. It would also cause a vacum leak and cause the engine to run bad.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler, this car is currently under rebuild and restoration.
Prodigious
Oct 4, 2015 11:20 PM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
Navy8125
Aug 21, 2015 09:32 AM
