Dumb question...
Old Sep 24, 2004 | 11:44 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Dumb question...
Is it possible to run roller lifters on a regular flat tappet cam ?
just something i've been pondering for a while...
Dave
Old Sep 24, 2004 | 11:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No
Not for very long, anyway
Old Sep 24, 2004 | 12:00 PM
Engine: 450HP 355
Transmission: TH350
Originally posted by RB83L69
No
damn...
so what's the diff ?
Just materials ?
the reason i ask is because there is currently no aftermarket roller cams offered for the Gen3 60 degree V6 (3400SFI). but there is a few offered for the Gen2 60* V6. i know i can run a regular cam in the 3400 with regular lifters but i was just curious....
Thanks,
Dave
Old Sep 24, 2004 | 12:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Metallurgy is one difference.
The main one though, is that a "flat" tapet cam, isn't flat. The rearward side of the lobe is bigger than the frontward side. That does 2 things: it makes the lifters retain the cam in the block, and it makes the edge of the lifter ride on the cam, which makes the lifter spin. "Flat" lifters aren't flat either; they're slightly convex.
So if you put a roller lifter, whose roller axis is parallel to the cam axis, onto a lobe whose surface is not parallel to the axis of the cam, things are bound to happen which are not good and involve metal shavings.
Just one more reason I don't fool around with 6-cyl motors.
Galaxie500XL
Oct 1, 2015 01:05 PM
Rally Smith
Sep 14, 2015 06:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
happyhapka
Aug 15, 2015 04:42 PM
White_Boii
Aug 27, 2001 09:31 PM
