Tstat housing bolt question
Old May 14, 2001 | 03:15 PM
Ben87GTA's Avatar
of the 2 bolts on the stat housing, the rear one (the major PITA) is it just a nut that comes off, or does a whole bolt with a nut on it come off.. mine looks like its a nut that is in the middle of a bolt... but the whole thing backed out a little, then started getting tough... I do NOT want this thing to snap ....
thanks for the help
-Ben
Old May 14, 2001 | 03:52 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
it is one long bolt. I had to take off the throttle body just to take out that one bolt.
Old May 14, 2001 | 06:36 PM
EO273KiD's Avatar
On mine, the rear was a bolt, and the front was a nut on a stud. I had to remove the throttle body to get at them, and I had to front stud snap off even after heeating it with a torch, that sucked, but i fixed it with a drill and tap..
Old May 14, 2001 | 07:23 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
After seeing this a couple of times it appears GM uses steel bolts/studs in aluminum manifolds with no anti-seize. After all, they never have to remove them once they leave the factory, right. I always put studs in the manifold (I do the same thing for the distributor hold down bolt - replace it with a stud). You can buy the right size at Lowe's (and they are grade 5 so they are plenty strong enough) for less than $5 and never have that problem again.
Z's r Best
Jeremys87
Jul 14, 2022 09:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
