Can the starter enable relay work properly sometimes and then junk out others? or is it something that either works or doesnt? thanks
They have been known to function erratically on occassion.
What are your symptoms and are you getting a security light on the dash?
What are your symptoms and are you getting a security light on the dash?thanks for the reply... security light comes on and then shuts off like its supposed to... i think ive figured out what my problem is though, the ground to the engine is ****, its needs to be cleaned up and all. thank for the help though
