How high can she go?
Old Sep 24, 2004 | 03:19 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
How high would you feel safe pushing a stock 81k-mile LB9 bottom end? I'm just trying to get everything worked out for my intake/head/cam/header/ECU swap and I'm going to change the stock shift points with a new governor weight.
How high can the pushrods go before bending? My buddy always tells me that I'll bend a pushrod if I go that high. If that's a concern, I'll pick up a new set of pushrods (hardened/chrome moly, etc.).
Old Sep 24, 2004 | 03:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What do you mean 'pushing'? Do you mean HP or RPM? If you mean RPM, I wouldn't go past 5500 with stock parts.
Its kinda pointless to go that high with TPI anyway, since it quits at about 4500 (5000 if modified right).
Old Sep 24, 2004 | 03:59 PM
Car: 1997 Corvette
oops...RPM
I'm not going to have the TPI setup anymore... LT1 intake with ported LT1 heads and a cam that's probably too big.
5500 though ya say? Hmm...
Old Sep 24, 2004 | 04:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by DuronClocker
oops...RPM
You cannot use LT1 heads on your 305. Stock bottom end should be good to 6k. Plenty of "built" 305's out there doing that everyday.
Old Sep 24, 2004 | 04:10 PM
Car: 1997 Corvette
All that is needed is for the coolant ports to be sealed up..
6k sounds good to me
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
