Here is a diff. question for you all...about turbos and brakes....
Old May 14, 2001 | 07:40 PM
F-Bird-87's Avatar
today i was working on a tubocharged-supercharged-6v Detroit diesel (4 stroke) engine and came up with this question....
ok if you have a vacuum brake booster it gets it vacuum from the intake manifold (or somewhere near there). but what if you have a turbo turning that vacuum into pressure? would that make your brakes harder to press? how does that work? or is my logic just so far out there you guys dont get what i am saying? thanks for any responces!
mike
Old May 14, 2001 | 07:52 PM
Jester's Avatar
Well assumably when applying the brakes your foot is off the gas normal vacuum is restored when the throttle blades close.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 14, 2001 | 11:24 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
vacuum canister and a check valve. except on a diesel. it works off a vacuum pump on them if they don't have hydroboost.
Old May 15, 2001 | 01:24 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The TTA's and GN/T-types use an electric pump to provide fluid under pressure for power assist purposes when the vacuum turns to boost. They also have an accumulator that stores high pressure fluid for their 'power brakes'. I think it gives you about fifteen normal applications of the brakes worth of stored fluid in the accumulator.
Most diesel engines use a form of engine driven pump to pressurize a fluid (power steering usually) that is used to provide power assist for their brake systems. They also use an accumulator to store pressurized fluid.
Some other diesel engines use a vacuum pump like others have mentioned that provides vacuum to operate any accessories as well as the power assist brake system.
Laterzzzzzzzzzzzzz
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old May 15, 2001 | 01:25 AM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by F-Bird-87:
today i was working on a tubocharged-supercharged-6v Detroit diesel (4 stroke) engine mike</font>
Which 6V was it? Lemme guess..... an oil leak. lol
LittleFranks
Sep 17, 2015 12:22 PM
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
