Which valve is the umbrella seal supossed to be on?
Old May 14, 2001 | 07:01 PM
IrocLouver's Avatar
I thought it was the exhaust valve. I bought Fel-Pro Viton umbrella seals and the box says Exhaust Set. But sure as hell the seals are on the damn intake valves. Can't anything be straight forward with these cars? (1990 L98 IROC)
Old May 14, 2001 | 07:05 PM
93ND500's Avatar
I've got them on both the exhaust and intake valves.
Old May 14, 2001 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's best to have them on both but they're usually only on the intake valves. When The intake valve is open the piston is on a down stroke drawing air/fuel into the cylinder. If the seal is worn out then it will also draw oil down the valve guide.
The exhaust valve seals only keep oil from leaking down into the cylinders when the engine is shut off.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 15, 2001 | 11:16 AM
IrocLouver's Avatar
Almost right. I called the Fel-Pro tech line today and the umbrella seals are only meant for the exhaust valves. The intake valves get the hard clamp style like the originals (SS72527). If you use umbrella seals on the intake valves you pull in too much oil during operation.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
