Occasional Miss and cutting out ....
Old May 15, 2001 | 07:34 AM
MY Z ROCS's Avatar
I have an 89 5.7L TBI that seams to continually want to spit, sputter, miss and cut out. It will run fine for a while (5 miles or so) then will bog.. and start spitting and sputtering. I have changed the fuel filter, plugs, wires, cap, and rotor.
What has me confused is that it seams to run great in between it's coughing fits. I figured it could also be a vacuum leak or a faulty fuel pump but wouldn't those make it do it all the time ??
All advice is appreciated .. Thank's
Old May 15, 2001 | 10:47 AM
FlashGTA
Guest
Posts: n/a
Check for a bad ground to the block. Also get a scanner and run a data capture when the problem arises.
Old May 15, 2001 | 02:25 PM
MY Z ROCS's Avatar
I am not getting any error codes out of it normally. I got an error code 44 once but after I cleared it, it has not come back but the problem persists ... the code 44 is a lean indicatio and the o2 sensor ..
Is it possible this could be something serious like a head or head gasket ???
Bubbajones_ya
Jul 6, 2024 08:32 PM
devilschariot
Feb 25, 2016 03:08 AM
FormulasOnly
Sep 6, 2015 10:42 AM
machinist21
Sep 5, 2015 03:03 PM
