Temp sensor not working
Old May 14, 2001 | 11:35 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I put a new temp sensor in and it it doesnt work. and its giving me a code 15. I have no Idea what it is. would this cause my car to run like crap and backfire? I have no clue what it could be.
BTW I used teflon tape to install would this have anyhting to do with grounding the sensor?
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old May 15, 2001 | 12:00 AM
Enkil's Avatar
I don't know about the code 15, but I'm pretty sure the teflon tape is causing some problems there...
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Vader's Avatar
Chris,
Which sensor did you replace, and are you certain you got the correct part?
The CTS for the ECM is an analog resistive device, while the sensor for a secondary fan is merely a temperature switch. The two do not interchange. The DTC '15' means the CTS circuit is open (disconnected) which is exactly what you would get with a temperature switch connected to the CTS input for the ECM. Once the coolant warm up and closes the switch, you'll get a '14' DTC.
You can check the resistance of the CTS at a given temperature and compare it to the table:
Old May 15, 2001 | 12:13 AM
Car: 1991 Z28
No I meant the coolant temp sensor is what I replaced. and it makes a code 15. you think it could be a short in the wiring?
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Old May 15, 2001 | 12:22 AM
Vader's Avatar
Chris,
I understood the original post, and was wondering if you somehow were given the wrong sensor as a replacement. If a temperature switch were installed in place of a resistive sensor, the problem you are describing would occur.
Check the resistance of the sensor. If it is open (infinite resistance) you have a dead sensor or a switch in place of the sensor. The '15' DTC generally indicates an open sensor circuit (no wiring connection or open sensor). If you had a short, the code would be a '14'.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 14, 2001).]
Old May 15, 2001 | 09:45 PM
Car: 1991 Z28
Do both of the sensors look the same
91 Z28 5.7l Camaro
more to come....
My 91 Z28
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Irocohio
Aug 12, 2015 08:03 AM
squiggy2
Aug 9, 2015 09:30 PM
