Where to use Anti-Seize and Threadlock
Old Sep 28, 2004 | 05:00 PM
92GTA's Avatar
I putting on my intake tomorrow and I want to be sure what needs Threadlock and what needs Anti-Seize.
Throttle Body Bolts?
Runner to Plenum Bolts?
Runner to Intake Bolts?
Intake to Head Bolts?
Stock Plenum, SLP Runner, Accel Intake, Stock cast iron heads....
Also any places in specific where I should use liquid gasket for extra seal other than the front and rear of the intake base?
Thanks!
Old Sep 28, 2004 | 05:05 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Where to use Anti-Seize and Threadlock
Thanks!
anti-seize should be used on anything that is aluminum that a bolt is going into the intake to head bolts need to have a dab of gasket sealer put on them you can put sealer on the intake gasket itself around all the water jackets
Old Sep 29, 2004 | 12:07 AM
92GTA's Avatar
Thanks...
DizzTransAm
Aug 15, 2011 11:52 PM
3rdgengmachine
Apr 8, 2010 06:03 PM
scanman717
May 10, 2004 01:45 PM
