Fuel Filter leaking
Old Aug 11, 2011 | 10:06 PM
DizzTransAm's Avatar
Car: '83 & '84 T/As
Fuel Filter leaking
I went to replace my fuel filter on my '83 T/A (Crossfire injection) and I primed it and noticed right away it leaking. Looks like its comeing between the filter and the fitting that seperates it from the fuel line. I took the fitting off the original (Yes it had the original filter on it!) and a red powdery substance came out of the threads almost like it had threadlocker in it. Should I threadlock/teflon tape it? I didn't see and crush washers when I took it out.
Old Aug 12, 2011 | 05:42 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Fuel Filter leaking
760 in the house!!!! Im from the Imperial Valley. HHHmmmm. I dont recall if there is a rubber o-ring on the lines. There shouldnt be any leaking unless you cross threaded the filter. I dont know if teflon tape is capable of withstanding gas. I would investigate if teflon tape is okay to use. I wouldnt use threadlock though. That stuff is tough.
Old Aug 15, 2011 | 10:59 PM
Car: '83 & '84 T/As
Haha What up 76o!
Got the fitting tightend up but now it appears to be leaking from the flaired outlet/nut area...
Old Aug 15, 2011 | 11:52 PM
Ahh man you know how we do here in the 105* summers. Can you take any pictures? A picture would help drasticaly.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
perZ
Aug 21, 2015 05:51 PM
