Cruise control won't engage.
Old Sep 28, 2004 | 05:10 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
While driving if I push in the cruise button, it goes in but wont engage. Why? Help will be appreciated.
Old Sep 29, 2004 | 08:45 AM
Cole's Avatar
Does your speedometer work? My cruise wouldn't work while I had the speedo/vss unplugged.
Old Sep 29, 2004 | 08:48 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
first thing i always check is the cruise button that gets pressed by the brake and clutch pedals.
if they arnt pressed in when the pedal is up, it always thinks the pedal is down and it wont turn on.
Old Sep 29, 2004 | 09:24 AM
Engine: 5.0L 305 H
thanks for the tips. I'll look into them.
Old Sep 29, 2004 | 12:05 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
does anyones cc work in here i have yet to see a thirdgen with a working one.
Old Sep 29, 2004 | 12:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
both my 91s, and my older 82s worked.
heck, i had the verts cruise working even when i swapped it to carb for a bit...
Cole's Avatar
PhAnToMs, I don't know if that was a rhetorical question, but mine works fine.
Old Sep 29, 2004 | 12:50 PM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
My 88 Firebird's CC worked when I got the car and then misteriously stopped a couple years later... I figured it just died, til a little while later the car started running like crap... found out it had a vacuum leak. Replaced the hose, and the cruise worked perfect again.
My 89 GTA the cruise works too... once in a while it acts up and won't work... my guess is dirty contacts in the switch maybe... but majority of the time it works.
Old Sep 29, 2004 | 01:16 PM
Engine: 5.0L 305 H
Wow, with just those few words you really opened up a can of worms, lol.
Old Sep 29, 2004 | 01:48 PM
Engine: 5.0L 305 H
A low down dirty trick
Yeah, I learned a dirty trick you can play on your friends w/ firebirds. In the engine compartment on the back wall above the the steering column there's a box with a vacuum line running to it. Disconnect that hose and the car will still run but extremely rough. I found that my 82 T/A was running really rough, the engine was sucking in air from somewhere. We finally found that that vacuum hose had disconnected from the plug and was sucking in air. Although! I strongly discourage using this trick on the innocent... or anyone who carries a firearm in their trunk. Messing with a person'spontiac is scrilege and blasphemy.
Old Sep 29, 2004 | 01:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: A low down dirty trick
heres one for the later ODBII cars.
go over and loosen their gas cap.
since its not pressurized anymore, it'll set off a code and the SES light comes on.
hours of fun.
Old Jan 6, 2005 | 01:58 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
What is the box from which you are disconnecting the hose called? I am trying to figure out if that has something to do with my HVAC and Cruise Control failing simultaneously...
Thanks!
Speedy
Old Jan 6, 2005 | 07:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Re: A low down dirty trick
Thanks!
Speedy
That box wouldn't apply to your car, it was only on the earlier models.
Old Jan 6, 2005 | 07:44 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
my cruise control cable doesnt fit under my open element air cleaner.. never got around to making it work
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Glowsock
Sep 6, 2015 06:40 AM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
