Door won't stay shut - what do I fix?
Old May 15, 2001 | 09:48 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Is this a problem with the pin? It seems like the door is missing a spring or something, the passenger side will stay open at intervals but the driver's side just swings shut. Anybody know? Thanks.
Old May 15, 2001 | 10:26 PM
Vader's Avatar
U ROCK,
Your topic line was a little confusing. I thought the door wouldn't stay shut. It sounds like you are saying it won't stay open. If that's the case, there is a cam plate and detent roller on the lower hinge of each door. A large spring maintains pressure on the cam plate. If the spring is broken or missing, the door will not stay open in its two detent positions.
Look at the lower hinge on the passenger door and compare to the driver door.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 15, 2001 | 10:54 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks Vader! Assuming I have to replace that spring, do I need to remove the door to do so...I've been looking through my helm manual and it doesn't say anything specifically about a spring...
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
