Honing Stone Grit Selection
Old May 12, 2001 | 05:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You motor rebuilders out there, I need your help!
Whats the right stones for honing. Is 320's to course? Or should I use 400's?
I know moly rings need a finer stone, but with all the different stone sizes I don't know what the right one is.
Also, do you use any type of lubricant (oil or ATF) while honing? All the books I see just tell you about the crosshatch but don't really go in-depth about grits and tricks & stuff...
Thanks.
Old May 12, 2001 | 06:26 PM
82camaro's Avatar
Car: 82 camaro SC
Unless this is on your lawnmower engine, I would take it to a machine shop. You will never get the proper crosshatch, especially if this is your first time. I know a handful of people that can hone good, but they have years and years of experience and in most all cases they have a machine shop do it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 15, 2001 | 08:00 AM
JoelOl75's Avatar
I've found myself a 10/20 4 bolt main motor that was redone .030" over, driven about 2,000 miles and pulled, oil pan and heads off and thrown on the floor of the guys garage. The cylinders mic out at 4.027 everywhere down the bore and there's no ridge... I could still see the crosshatch....
The problem is all kinds of dirt, sand, leaves, ect. was all up inside there so after flipping the block upside down and brake parts cleaner to try to rinse it out, lubing it back up well with some oil, I popped the pistons/rods out for a good cleaning/re-ring. I have the hone and 320 and 400 grit stones and borrowed a deck plate so I'm going to do this, but some insight would help...
I'm figuring on skipping the 320 and going right for the 400's....
Everyone who could do this must of had a 'first time'
Main thing I need to know is what lube do you use while honing? 30 weight OK or ATF? or is there something better? Any help greatly appc'd!
Old May 15, 2001 | 08:14 AM
82camaro's Avatar
Car: 82 camaro SC
When I do mower/small tractor engines, I use HD30. But I've heard of people that use ATF. You'll get done faster with ATF because it's thinner and has less 'lube' in it.
82camaro
Old May 15, 2001 | 09:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The grit depends on the rings you're using. For cast-iron or chrome, use a coarser stone; for moly, the fine grit. I prefer ATF as the lube, it provides the necessary fluid without gumming up.
If it's at 4.027", I'd suggest using the 320 or even a 220 first, especially if the pistons are forged. IMHO that's too tight for a performance bore fit.
ICON Motorsports
Old May 16, 2001 | 07:20 AM
JoelOl75's Avatar
Thanks for the info, ATF it is. I found it quite odd to have the bore that tight and I had my mic checked at work and even borrowed my friends and it checked the same.
I have no idea who did the bore job, but I guess under is better than over!
grngryoutmyway
Oct 18, 2016 05:48 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
GTAman
Sep 26, 2015 02:01 PM
RyanJB
Sep 14, 2015 03:39 PM
