Vibration
Old May 15, 2001 | 11:39 AM
BenIroc's Avatar
Vibration
I´`ve got an engine vibration at 4200-4500 rpm.When the trans is in neutral, i does the
same thing so it is not the trans or the shaft.
If I put the base timing at 2 before TDC the vibration is less than if the timing is at
8 before TDC.At 2 after TDC the vibration is almost gone, but the car does not work OK in
lower rpm.With the timing at 8 or 10 before
TDC, the car runs great untill I hit 4200 rpm.
Any ideas?
89 iroc, 350 motor.
Old May 15, 2001 | 03:10 PM
BenIroc's Avatar
Anyone?
BenIroc
Old May 16, 2001 | 03:58 AM
BenIroc's Avatar
Back to the top, last try.
Old May 16, 2001 | 10:21 AM
Ken88GTA's Avatar
Just a guess, but maybe your harmonic balancer?
Good luck,
Ken
Old May 16, 2001 | 02:35 PM
poncho9789's Avatar
the balancer would be my bet or you have some strange misfire I have been told that you can have problems with the ignition module in the hei and as the rpms go up it can cause a problem such as that.
good luck
Old May 16, 2001 | 04:39 PM
BenIroc's Avatar
That`s what I thought to so I put a new balancer, the old one was finished anyway
but the vibration continued with the new balancer arrrrrgghhh.
Thanks anyway guys.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
