Help Missing sensor
Old May 16, 2001 | 01:42 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Help Missing sensor
Well I am putting the bottom of the car together today and I pluged in the Torque converter harness to the tranny and I found a two prong plug coming out of that harness and I have no idea where It goes (not the o2 checked that) I can't find anyting else down there and its wires are not long enoughh to get back up to the motor
Thanks again
Brian Felts
Old May 16, 2001 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What color wires?
ICON Motorsports
Old May 16, 2001 | 03:49 PM
Purple and yellow
THANKS
B
Old May 16, 2001 | 03:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like starter safety switch, maybe on the shifter, especially if they're real thick wires
ICON Motorsports
Old May 16, 2001 | 04:25 PM
Well the wires are short about 6 to inches. I did install a Megashifter a while back could that be it?? I just can't see anything near the block or the tranny that has any connector (or two prong) I got the Torque converter 4 prong, the o2, the little one on the driver side head that goes into the water passage but now I am lost.....
any other opinion or could it have been a never used plug.
Thanks again......
Brian
Old May 16, 2001 | 04:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are they thick wires? Could they plug into the shifter area? If so, that's what they are. Yellow = power from the ignition switch START contact, purple = wire that goes to solenoid
ICON Motorsports
Old May 16, 2001 | 07:42 PM
yeah they are kinda thinck I would guess. Did we do away with the terminal when we went to the mega shifter....
THANKS AGAIN
Brian
Old May 16, 2001 | 10:04 PM
GTABANDIT's Avatar
Brian check and see if it goes to your speedometer sennding unit located close to the driver side tail housing hooked mine up today i hope this helps if not e-mail or post!!
Old May 17, 2001 | 07:43 AM
NO nothing on the speedo........it has a cable driven one. I am lost but I think the best idea was the neutral safety switch... I have no idea.
Brian
devilschariot
Feb 25, 2016 03:08 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
