what connecting rods in 79 350?
Old Oct 2, 2004 | 08:54 PM
305LG4Cutlass's Avatar
I'm doing my first engine build to replace the 305 in my Cutlass. I'm just trying to figure out what all I'm going to do to the bottom end. This is basically going to be a low budget engine, i plan on doing a big block olds in a few years but we have this 350 sitting here and I figured my first engine build should on something as common and easy as the SBC. I'm running mid 15's right now with the LG4 and 3.73's. I want to run low 14's (before suspension work, and using crappy tires).
Anyways here is the question. The engine I'm building is a 79 350 4 barrel out of a Caprice wagon. It is not taken apart yet. Does anyone know what connecting rods would have come in it and what kind of rpm's can they handle? I will be getting it bored .030 over and new hypereutectic pistons and rings and decent bearings. I know the cast crank and 2 bolt main can hold up to pretty good rpm's but I was just wondering what these rods can take and if I should be bothering with ARP rod bolts and main studs? The engine probably won't ever see over 6000rpm. I just want to know that its not gonna blow up on me. I like the way I can run my 305 to the top of its powerband (5000rpm) all day long and nothing ever seems to wear it out.
Old Oct 2, 2004 | 09:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Stock forged rods. The bolts are the weak link not the rod. With new bolts they will support 500+ hp.
Old Oct 2, 2004 | 10:21 PM
ede's Avatar
ede
replace rod bolts with arp bolts and have rods resized and you'll remove the weak link
BRoss99
Aug 10, 2025 05:08 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
