Tire Size
Old Oct 3, 2004 | 08:12 AM
minnesotamp's Avatar
Car: 1986 Trans Am, 2003 Silverado Z71
Tire Size
I was wondering what is the largest tire you can fit on the rear of trans am with a rear end out of a 95 Z28 is. It has disk brakes I don't know if that will make a difference. Other than a different rear end the rear is stock. I was wondering because my buddy has a set of slicks I wanted to buy and use. I would just try them on the car but I am in South Korea right now and the car is in Minnesota and the tires are in VA. So you see my dilemma. Any help would be appreciated.
Old Oct 3, 2004 | 11:12 AM
Vader's Avatar
MN MP,
With stock springs, correct wheel offset, and a properly centered axle, you can install up to 12" wide and 27" OD tires, or about 275/50-16 on the rear. The fronts will not have clearance for those tires, however.
Other similarly sized tires would be 275/45-17, 275/40-18, etc.
South Korea? I hope you took a jacket (both kinds). Headed back soon? If so, you might be looking for snow tires before hunting down those slicks.
Old Oct 4, 2004 | 07:44 AM
Vader
Yeah I am heading back in the end of March next year. I hope the snow, salt and sand will be off the road so I can take the T/A out of storage. So I can fit 12 inch tires under my T/A in the rear with the 4th Gen rear end under it? here is a Pic of my T/A. I just figured out how to get a picture on the website. I couldn't get them small enough before.
Anyone?
What is the biggest tires anyone has put on with the rear end out of a 4th gen? What was the rim size and the offsets? Anyone?
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
