taking out A/C
Old May 17, 2001 | 06:29 PM
AirN1's Avatar
taking out A/C
how should i probperly discharge the a/c canister and lines.....withour bringing it and hooking up to a evac. machine. can u just lossen the lines and let it bleed?
Old May 17, 2001 | 07:55 PM
Enkil's Avatar
There's high-pressure in some of those lines, I'd be careful with that. What you should do, is take a .22 calibre rifle and a decent scope, and shoot it from a good distance.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old May 17, 2001 | 08:01 PM
82camaro's Avatar
Car: 82 camaro SC
You can just let it bleed. However, if you have R12 in those lines and if it's a substantial amount, you may get a refund. That stuff is expensive and the cost to pull it out should be resonable if you just have the freon pulled out--not the full vacuum service.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 17, 2001 | 08:58 PM
86Trans Am's Avatar
Seeing that it would be easier to take it out in pieces, can i just get the freon sucked out and be good to go?
I am still torn as to whether or not to take my ac out, it works fine, but i have not used it once. I guess the weight savings isnt that big of a deal because my car isnt fast in the first place, maybe i'll just wait until i build the real 400 for it (pontiac, 400 that is)
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
85Special
Sep 3, 2015 04:21 PM
