Flooding problem... I think
Old Oct 4, 2004 | 12:42 AM
RallySport92's Avatar
I've got a '92 RS that just had the 305 replaced with a 350. Kept the same TBI on it. Now it floods all the time. Dies at take off, smells of gasoline, you know... Was wondering if anyone had an idea of how to get this thing running correctly again?
Old Oct 4, 2004 | 06:54 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Have you plugged a scanner into it?? Might be rather informative. Coolant temp sensors have been known to cause this type of behavior.
Old Oct 4, 2004 | 08:09 PM
sellmanb's Avatar
Car: '86 Berlinetta
Coolant Temperature Sensor, Oxygen Sensor, carb not tuned right, or leaky injectors (cant remember if you said carb or FI sorry)... if it's FI then you need a chip burnt to 350 specs to go along with your new cubes.
BTW, how much did it cost you for the 350 swap? Did you just take the block and bottom end from a junkyard and put the new motor mounts and top end and accessories on it to save money?
I'm thinking about doing the swap if my bottom end is toast, and I wanna know what I'm getting my wallet into
Old Oct 5, 2004 | 12:56 AM
No, haven't plugged a scanner into it.
Engine swap cost me $850... don't recall if the bottom end was swapped or not... I'm thinking it wasn't.
Guess I'll try the coolant temp sensor first... Thanks for the info guys.
Zane Story
Oct 8, 2015 12:40 PM
Wade787b
Sep 29, 2015 01:15 PM
Metalman
Carburetors
Jun 1, 2001 09:00 AM
82camarov6
May 3, 2001 07:43 AM
Alan84TA
Mar 29, 2001 04:41 PM
