Friend of mine needs some help.
Old Oct 4, 2004 | 06:02 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
His vehicle has been leaving him stranded QUITE often and I cant figure out whats going on. If it sits overnight it'll start right up and run for quite some time....then die.
I've determined this much.
He's replaced the fuel pump 2x in the past 3 years. (he's on his 3rd pump)
After it quits running and you turn the key to the "run position" you can hear the fuel pump run constantly.
After the no start and the pump constantly running, when you turn it over it gets NO fuel to the injectors.
What I'm not understanding is how the pump is working....then not. When it stops working (pumping) it's like it's just trying REALLY hard to catch a prime.
Any ideas? Thanks in advance!
Edit: Oh, and....it's a 2-bbl TBI
Old Oct 4, 2004 | 06:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I would check the relay.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Sep 14, 2015 06:37 AM
sandman92084
Sep 12, 2015 10:27 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
