CFI to Carb
Old Oct 5, 2004 | 08:42 AM
nevikrmsw's Avatar
Car: 86 Iroc
Transmission: 700-R4 automatic
Axle/Gears: 3.73 posi
CFI to Carb
how hard would it be to switch the CFI over to a carb setup. i don't like the CFI and would like to use carb, what all do i need, how expensive/difficult would it be?? any suggestions on carbs/intakes would be helpful.
Old Oct 5, 2004 | 11:07 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
To swap you'll need a carb, FP regulator, new ditributor (mechanical), and an intake. Then you'll need to tinker and tune; throttle cable bracket, jetting, timing, etc.
FWIW, you can support over 300 hp w/the CFI intake by porting it...all for the cost of a plenum lid gasket and intake gaskets. It's an increadible bang-for-the-buck imporvement that CFI offers simply because the manifold in stock form is so bad. I personally advocate doing that, as you retain the advantages of EFI. JMHO.
-Tom
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
