Help with Steering Columns! Urgent
Old Nov 8, 2001 | 03:38 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
After rereading I basically wanted to say that I want to switch to CC and tilt. I have a 1988 Camaro Convertible SC, auto, If VATS is the electronic key, than no I do not have that. Thanks
I am wanting to switch to a tilt/CC steering column from my non-tilt/non-CC. what do I need and how hard is this to do, I am hitting the junk yard tonight so please help. If it wont work ill have a Steering column for sale :-) Since I do not have power windows or door locks :-( I was thinking of placing the controls there, because I have a GT steering wheel. Also can the old cylinder lock be used on the new steering column? Thanks guys
James
1988 Camaro SC Convert!
4th gen conversion coming soon!
[This message has been edited by Jstcrzyengh (edited November 08, 2001).]
Old Nov 8, 2001 | 06:24 PM
ede's Avatar
ede
swapping columns isn't that hard, just a few bolts and wiring harnesses to remove. you'd need all the CC stuff from a donnor car and that would be hard to connect. i'm pretty sure the 2 columns would be the same as far as bolting up and wiring connections except for the CC, but i'm not 100% sure since i've not swapped one.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 9, 2001 | 10:15 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The CC controls are a separate wire, so you could just leave that unplugged.
To swap in the cruise control, let's see what you need:
Turn signal level with cruise switch on it.
Cruise Control computer (behind the dash, near the right defrost vent).
Vacuum "ball" reservoir (under the left headlight area on Camaros).
Vacuum servo (near charcoal canister on Camaros) with cable.
Add-on bracket to attach cruise cable to throttle cable bracket.
VSS (if you don't have one, mine didn't--if you have an auto you will already have it)
Pedal switches (one for the clutch and one for the brake)
Lots of wire and vacuum line .
It's not a terribly easy swap. Mine hasn't worked since I swapped motors, I think the cruise computer got damaged somehow. I'm more worried about getting the car running than fixing the cruise at the moment.
Old Nov 9, 2001 | 12:07 PM
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by 99Hawk120:
</font>
Thanks guys! That SO helps! Hawk thanks for the break down of parts needed. I am picking up the column with the controls here on Saturday. I will pick up all of those parts. Thanks that really helps. Can you give me a bit of a description the best way to go at an install? I was thinking about using the haynes manual and either back installing or using their install instructions and just hoping it works lol Going to vegas in december I want it up and working by than lol Thanks
James
'95 Black power leather Z28 seats
MSD 6al
8.8 mm custom made wires
MSD hi po coil
MSD hi po distributer
K&N Open element 14x3
more coming soon!
Old Jul 29, 2004 | 09:52 AM
SS427_IROC's Avatar
Car: 1987 Camaro IROC SS427 (Motion vehicle)
Engine: 427cu.in. Small Block
Transmission: 700R4 (soon to change)
Cruise Control Computer...
If 99Hawk120 is still around, I have a question for him regarding his reply. When you talk about the 'cruise control computer', I presume you're talking about the normal vehicle computer. What is different about the computer on a vehicle with cruise versus a non-cruise control computer?
I'm adding power windows, locks, tilt, intermittent wipers and cruise control to my IROC.
Old Jul 30, 2004 | 03:19 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
not to hijack but do manuals have CC? I found a ball on my 88 under the driver side battery tray, I'm guessing thats what that is right?
Old Jul 30, 2004 | 03:26 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it was an option for both manual and auto trannys.
Old Jul 30, 2004 | 03:49 PM
SS427_IROC's Avatar
89RsPower, do you know about the 'Cruise Control Computer'? I have someone who is parting out an 86 Camaro and I need to let him know if this is the same as the car's computer or if it's a seperate unit.
Old Jul 30, 2004 | 08:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It's a separate unit. There is a smaller black box with the only writing on it being "AC" and probably a part number. The ECM has two huge connectors and is a rather large metal box compared to the tiny CC computer. There is a single connector that has around six pins that runs into the CC computer. Don't forget to grab the bracket that it is mounted to that is actually bolted to the dash so you don't have to hear the thing rattling around all the time...
You only need to remove the lower convenience panel (same color as the rest of the dash, not the thing mounted in the footwell with the light) to get at this box.
Old Jul 31, 2004 | 11:53 PM
PITA's Avatar
Maverick, thank you very much! I'm hoping this will turn out to be easier then it sounds. Will let you know once it's done.
Old Aug 1, 2004 | 03:47 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Anytime. You might want to look to see what you already have in terms of the necessary harness connectors before you go cutting and splicing wires into the dash harness, to save unneccessary headaches later.
Old Oct 5, 2004 | 02:17 PM
SS427_IROC's Avatar
OK, I now have all the parts previosuly mentioned by 99Hawk120; Does anyone know here I can find detailed instructions for adding these components as well as some 'exploded' diagrams showing how they should attach to the vehicle and where. Thanks for everyone's help. :hail:
Ed1LE
Sep 30, 2018 09:14 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
