Stripped Allen Style Bolt?
Old May 17, 2001 | 01:07 PM
Abe91Z28's Avatar
Ok, i've been trying to get this bolt off my car, but the head of it is an Allen style head. The head is stripped. I mean i can put a Allen Wrench in there, but it just turns, w/no luck of moving the bolt at all. Its completely round in the middle. Any suggestions on how i can get this bolt out of my car?
thanks in advance
-abe
Old May 17, 2001 | 01:11 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Can you get pliers/vice grips on the head? That'd be your easiest solution.
Otherwise you'll need yourself a drill and an extractor set. Basically, you drill a small hole in the middle of it, then you put the extractor in. The extractor is basically tapered left handed drill bit, so as you turn it to loosen the bolt, it digs into the hole.
Also, you might be able to take a hacksaw blade/file and cut a groove for a screwdriver.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 17, 2001 | 01:29 PM
Jester's Avatar
You might be able to get a torx bit thats slightly larger than the round hole..and hammer it in.
or weld a regular nut onto the head of the allen head through the middle of the nut
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 17, 2001 | 01:53 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
couple solid hits with a chisel and hammer on the edge of the head.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old May 17, 2001 | 03:56 PM
poncho9789's Avatar
yea bottled power but he would have a hell of a time taking out the threaded section of the bolt.
Old May 17, 2001 | 04:21 PM
93ND500's Avatar
Drill into the bolt and then use an Easy-Out. Just don't drill larger than the size of the bolts shank.
Old May 17, 2001 | 11:45 PM
Abe91Z28's Avatar
got some Easy-outs today. I'm gonna start tomarrow with the smallest size, and if that doesn't work, atleast i have a few sizees i can mess up on b4 i totally wreck it
Thanks alot guys.
-Abe
Old May 18, 2001 | 10:55 AM
Abe91Z28's Avatar
I got another question about easy-outs,
So, i just drill the hole in the bolt, and screw in the easy-out clockwise? the instructions aren't really clear... after its screwed in, i just remove it like i would a normal bolt?
thanks,
-abe
Old May 18, 2001 | 11:01 AM
Vader's Avatar
Abe, the screw extractor will have to be installed counter-clockwise. Once it it seated in the drilled hole, you might want to tap it lightly into place with a small hammer to seat it firmly. Turn the extractor counter-clockwise to remove the screw. If the screw is seized, you should have been using a penetrating oil to loosen the bond.
Two cautions to be aware of. Allen cap screws are generally much harder than even grade 8 fasteners (or metric 10.8 spec bolts), so drilling can be difficult unless you have a cobalt ot carbide drill. Also understand that the extractors can be broken easily, and are very difficult to remove once broken. Avoid any force on the extractor other than twisting. If you force teh extractor sideways while turning, it stands a good chance of breaking, then you'll REALLY be screwed...
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
gixxer92
Sep 1, 2015 04:32 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
