Brand new mechanical oil press gauge weird?
Old May 18, 2001 | 01:59 PM
GilmourD's Avatar
OK, I just installed a Summit mechanical oil pressure gauge in my car. I used copper tubing instead of the plastic crap that headers love to eat. Now my problem is that the damn thing reads really low, and my oil level is fine. It doesn't really go above 25psi, and idlingin while in gear, it drops to 0. Highway driving at about 2K RPM it stays a steady 20. What's the deal here? Air in the tubing that needs to be blead out? Dead oil pump? My piston rings are shot?
1986 Firebird, LG4 305, bored .040 over, Crane cam, Edelbrock headers, Hooker Aerochamber muffler, loud and fast.
"Gimme fuel, gimme fire, gimme that which I desire!" - Metallica, "Fuel"
Old May 18, 2001 | 03:51 PM
ede's Avatar
ede
it could be that the gauge is accurate and you have oil preasure problems. i'd screw another gauge in the block if i could, or replace the gauge to eliminate that as the source of your problem.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 18, 2001 | 05:54 PM
GilmourD's Avatar
Well... If it's not the gauge, what could the problem be? I don't think it's the rings, cuz I don't get oil on the plugs. What else could it be?
Old May 18, 2001 | 06:00 PM
Bort62's Avatar
Loose Bearings.
Verify That it is the Gauge First, Tho.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 18, 2001 | 09:55 PM
GilmourD's Avatar
Loose bearings, as in the main bearings??? What other symptoms might loose bearings have? LOL Explain to me in detail. Consider me a moron. LOL
Consider this, though. I drive the car daily, it shakes a bit while idling in gear, but the driver's side motor mount and tranny mount are shot (I've already got a Energy Suspensions tranny mount). It's a bit rough starting up in the morning, but later in the day it's fine, even if I don't start it up for hours. The carb does pop every once in a while (bottom side of the air cleaner top is blackened). And while driving, the car is powerful as all hell, considering that it's an LG4 that I replaced the carb and intake (Edelbrock 1406 and Performer RPM) and ripped off the smog pump and crimped off the AIR tubes.
Old May 18, 2001 | 10:05 PM
82z's Avatar
82z
Are there any kinks in the tubing? Use another gauge to confirn your new one is accurate. I can't imagine that you have 0 psi in gear. Do your valves start to tick really loud when the gauge reads 0? What did your dash gauge read before you installed the new gauge?
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old May 18, 2001 | 10:07 PM
GilmourD's Avatar
One problem with the old dash reading... There was none. The stock dash is no longer in the car, and that had dummy lights. Old gauge was always pegged at the very top. That's why I got this gauge... As far as I know, no kinks, but I'll check that.
Old May 19, 2001 | 12:01 AM
GilmourD's Avatar
bumpity bump bump
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
gwade12
Aug 8, 2015 08:17 AM
