Corvette motor info ?
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
I just picked up a 91 Corvette motor and am looking for a little info on it. Does anybody have a link to a C4 web site or board with tech data on this motor? I am mainly interested in cam specs, HP, comp ratio, and whether they used flat top pistons or dished pistons with smaller combustion chambers to get the ratio. I read that these alum heads had 55 cc chambers, is there anybody on the board running these heads with flat tops in their Thirdgen?
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
http://100megsfree4.com/corvette/1990/vet91.htm
hope that helps somewhat. this is it, unless its the zr1 motor. o_O
Feature Standard Engine (RPO L98)
Type V-8, 90-degree Overhead valve
Block Cast iron block and aluminum cylinder head
Displacement 350 cid (5.7 liters)
Bore & Stroke 4.00" x 3.48"
Comp. ratio 10.0:1
horsepower 245 @ 4000 (250-hp for hatchbacks using 3.07:1 rear axle due to use of low-restriction mufflers with this option combination only)
Torque 340 lb-ft @ 3200
Main bearing five
Valve lifters hydraulic
Fuel supply Tuned-port induction (TPI) system
Comp. ratio 10.0:1
Main bearing five
ambainb
Apr 25, 2016 09:21 PM
