305 manual vs. 350 automatic (both TPI)
Old Oct 8, 2004 | 01:51 PM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
What are the differences in handling and performance between these two?
The reason why I ask is that a friend who had driven a 350 auto said my 305 manual seemed to have noticeably less low end torque/power. The wheels wont't spin as easily at low rpm:s.... are these cars that different or is there something wrong with mine. In this case, what?
Should also add that my car has no cat and is chiptuned so about 250 hp. Shouldn't that make it atleast equal to a stock 350???
Old Oct 8, 2004 | 01:53 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
maybe your guess of 250hp is a bit much well more than a bit
Old Oct 8, 2004 | 02:09 PM
Car: Red '89 GTA
Engine: TPI LB9
I didn't make the guess so don't know... How much would these mods give then? How many hp:s should my car have stock?
Old Oct 8, 2004 | 02:51 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
stock 230@4600 hp and 3200 ft/lbs but the site also says take 5-10hp from the tpi on birds for intake design
i dont know the 350 year your friend drove but most power is this year 245@4400 345@3200 92 91 90 only 15more hp stock but 45 ft/lbs which is alot and u notice the tourque the most
i dont know estimates with though mods
Old Oct 8, 2004 | 02:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The 350 does have quite a bit more torque than the 305. Any handling difference you might feel would probably be the rear end getting squirelly by getting on the throttle too much.
Old Oct 8, 2004 | 06:31 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
What brand/size tires are you running, that makes a huge difference in tire spin.
My 86 LG4 5 Speed Trans Am would roast 225/60/15's all day long without dumping the clutch at low speeds/rpms. With the same setup and 275/40/17 BFG KDW tires the car would bog a bit and then go with no tire spin at all.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
