Coolant leak - DOESN'T LOOK GOOD!
Old Oct 10, 2004 | 05:57 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Hey guys - we're talking about an 88 lo3/700r4.... I'm leaking coolant pretty badly from the flywheel, torque convertor area... It appears to be leaking right off the bottom of the convertor - what do you guys think it is?
Thanks a ton guys,
GOY
Old Oct 10, 2004 | 05:59 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
could be many many things ..
bad freeze plug in the engine ?
could even be a bad hose on your heater core leaking down
have you looked from the top down with a drop light to try and pin point it ??
Old Oct 10, 2004 | 06:02 PM
1320 Right Ln.'s Avatar
FW/TC area eh?.... I had a coolant leak above that area, the intake manifold wasn't bolted down tight enough and the coolant was leaking out from the bolt hole, dripped down the back of the block, onto the trans, and finally dripped to the ground from the inspection cover. See if you can trace the line of water, you might just have the same problem i did.
Old Oct 10, 2004 | 06:03 PM
GOY's Avatar
GOY
Yeah, I briefly looked at it from the top. I was primarly looking for an intake gasket leak of some sort - but then reasoned that since it was leaking from the convertor cover itself, that it would probably have to be leaking from inside the bellhousing someplace.
How big of a pain is it to do freeze plugs?
Old Oct 10, 2004 | 06:04 PM
GOY's Avatar
GOY
I'll see if I can trace the line more accuraely, good idea, thanks.
Old Oct 10, 2004 | 06:22 PM
THEGENERAL's Avatar
definatly check the intake first before you go buying anything else
if its a freeze plug inside the bellhousing area then you will have to drop the transmission and punch a hole in the freeze plug without driving it into the block ....i usually just use a drill and drill a 3/8 hole in it and then pry it out with a strong screwdriver or punch
when reinstalling make sure to use sealer on the plugs and tap them in i use a socket just small enough to fit into the plug ....
also dont drive the plug in too far ...look at the one thats in there now thats how far the new one needs to go
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
mizz0313
Aug 12, 2015 06:45 AM
