block number... ??
Car: 91 rs
Engine: 250
Axle/Gears: stock??
block number... ??
ok so this always happens to me.. notings were it's spouse to be... i look were the block number spouse to be and all it says is 197 and i looks to be screwed on with a screw at each end on the number. were would my block number be then
Transmission: 4L80E/4L80E
The block casting number is behind the driver's side head.
It's cast into the bell housing casting.
I've heard of replacement blocks, such as the Goodwrench or Targetmaster lines, not having a "proper" casting #.
Did you check the s/n pad located in front of the passenger side head?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Car: 91 rs
Engine: 250
Axle/Gears: stock??
yeah i already look at the mortec site. and i'm almost pos. that that is the block number cause it's 7-8 charters long. no letters. and it fits the first 3 or alot fo the codes
The "140xxxxx" is your block casting number.
You need to get the rest of it. It could be a 305, 350, or 267. Most likely it's a 305, though.
Car: 91 rs
Engine: 250
Axle/Gears: stock??
no it's a 5.7 it says that on the drivers side ledge. 5.7l g on one angle of the ledge then the one above it it says 197. and the other side it says a bigg code
Car: 82 Z28
Transmission: TH350
It probably one of these 14010201...305...80-85...2. This is what i have in my car. You can also find the last 3 digits of the casting # cast into the side of the block, 4-6" above the pan. When i had my car jacked up i saw 201 cast into the side, just another aproach, if you can't see the whole number back there.
Car: 91 rs
Engine: 250
Axle/Gears: stock??
it's a 5.7 it's not the stock motor i'm just trying to find the block number so i can figure out what kinda 350 it is. ididn't put ti in the previus owner did. now i get to miss match parts. heads are next
Car: 82 Z28
Transmission: TH350
It doesn't matter what 350, it is. There negible differance between 350 blocks, that is if it really is a 350. There is no way to tell what 350 it is by the casting #, if the motor has been screwed with. I mean i could have been rebuilt to competely different specs. So you really won't know anything, you will just know what block you have.
Car: 91 rs
Engine: 250
Axle/Gears: stock??
yeah well it was rebuilt but it only cost him 1200 bucks to do. so i'm not thinking anything was done to it. beside a diffren't intae and carb. i'm checking the block number then the head number seeing if they match. if they do i know what stock hp i am makeing
Car: 82 Z28
Transmission: TH350
You do, how? The casting number doesn't tell you what vehicle it came from. You need the suffix code on the front passenger pad of the block to do that. If its been rebuilt and decked, to bad you will never know. You will just know what HP range that block was used for. The 3970010 block was used in everything from Camaro's to trucks, from 150hp-350hp. It doesn't mean anything tangible, but it may give you a warm fuzzy feeling, i don't know.
Car: 82 Z28
Transmission: TH350
There is no way to tell what engine you have, you can only tell what block you have. There is a difference and it is a big difference.
The block casting # may give you the desired warm fuzzy. And confirm it is acutally a 350 and not a 305.
The head casting #'s will tell you if there's any potential there. If they end in "882", then you know he got less than the $1200 he paid.
That still doesn't tell you the critical cam specs. With the casting #'s, you'll have a better handle on potential, but w/o the cam information, you'll be clueless as to the power you should be able to expect.
skinny z
Oct 5, 2015 06:23 PM
