what the hell just happened?!?!
Old Oct 11, 2004 | 07:32 PM
racleon's Avatar
Car: 89 Camaro RS
Engine: Caprice 305 tbi
Transmission: 5 speed manual
i stopped behind sum guy and he decided to park to i tried to go around him but i forgot it was in 4th gear so i went around him doin 3mph at like 4000 rpms then wen i get to the light i put it in nutral to downshift to fist cuz i was stoppin and even tho i took my foot off the gas it like stayed at like 2500rpms so wen i put it in first i jus took the turn and put it in nutral and took both feet of the pedals and it kept givin gas so i pulled over and turned it off. i sat there for a minute and turned it back on and drove home like normal. can anyone tell me what happened and should i be worried?
Old Oct 11, 2004 | 07:37 PM
sellmanb's Avatar
Car: '86 Berlinetta
sounds like a major vacuum leak, but i really dont know, i'm waiting around for other people to speak up as well.
Old Oct 11, 2004 | 07:49 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
sounds dumb, but check the plastics around the floorboard. i've had them come up and get stuck on the gas pedal a few times. pretty scary **** when you drive an auto.
Old Oct 11, 2004 | 09:37 PM
racleon's Avatar
Car: 89 Camaro RS
well i heard that if u dont let it warm up it can do that somehow. the car was turned on at 8 in the mornin wen i brought it to the shop and wasnt turned on again until i picked it up around 6. and it was cold all day so could that be it? if that could be it someone please verify for me.
THANKS
Old Oct 11, 2004 | 09:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
In open loop your car will idle higher. This builds oil pressure and heats up the motor faster. It is not uncommon for a TBI motor to run at 2k rpm on cold start-up. I bet your tach is off just like every TBI vehicle on the road and your motor really isn't running that high. Double check the obvious things like floor mats and carpet that can reach up and grab the gas pedal. Also, play with the throttle under the hood (car off) and see if it sticks open. Many TBI units need a good cleaning around the throttle spring shaft.
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
